After a rather long development cycle the Jellyfin team is proud to announce stable version 10.8! This release post will mostly cover the highlights with little prose, as there is so much to cover!
Download Jellyfin 10.8.0 Read the full release notes
All of the changes, accumulated over nearly the last two years, are too many to easily list, so we’ll break them down in the sections below and hope all of you find something enjoyable.
The major highlighted changes are:
numerous improvements to Hardware Acceleration (HWA), including:
Dolby Vision Profile 5 and 7 tone-mapping
CUDA-based tone-mapping for NVIDIA
extended OpenCL tone-mapping for Intel
hardware based subtitle burn in
Intel tone-mapping support for Windows
full OpenCL filtering for AMF on Windows
deprecation of OMX for raspberry pi, use V4L2 instead
proper network interface binding and handling of proxied requests
various fixes for DLNA, Sync-Play and m3u HTTP streams
DLNA disabled by default
extended NFO metadata import
external audio and subtitle support including container (mks, mka)
extended plain folder parsing
enhanced detection and handling of DVD/BD ISOs and folders
extend TMDb metadata provider (series state, season names, tags, logos, etc)
Some major fixes include a number of HWA improvements, explicit network interface binding, DLNA improvements, better NFO parsing, configuration cleanup (relics of the migrations in 10.7.z), and numerous metadata improvements, as well as the migration to .NET 6 which provides a nice stable language base for future improvements.
A point-form list of the changes compiled by the team is:
General:
automatically migrate and cleanup config files
reduce memory footprint by various optimizations (e.g. reducing memory traffic)
rewrite QuickConnect
splashscreen in branding API (although not in use by any client yet)
various HDHomerun fixes and improvments
properly read filesize from symlinks
create output directory on file extraction
return path to pinfile on password reset
fix ombi auth through Jellyfin
include genre in related media generation
Implement more provider links for series, seasons, episodes and movies
properly handle gif
passwords are now hashed with 120000 iterations of PBKDF2-SHA512 instead of 1000 iterations of PBKDF2-SHA1, old passwords are migrated automatically on login
add config option to disable automatic server discovery
Networking:
fix explicit IP/interface binding
disable UPnP by default (only applies to new setups)
proper handling of published server URLs
disable DLNA server by default to avoid security risks
HWA:
implement CUDA-based tone-mapping for NVIDIA
extend Intel OpenCL tone-mapping (speed-wise on-par with VPP tone-mapping and therefore preferable)
implement full OpenCL HW filtering for AMD on Windows
implement hardware-based subtitle burn-in (significantly faster)
implement proper tone-mapping support on Windows
add CUDA & OpenCL tone-mapping support for Dolby Vision profile 5 and 8
various other fixes for NVIDIA and Intel hardware acceleration
add support for AV1 hardware decoding on supported platforms
deprecate Raspberry Pi OMX/MMAL hardware acceleration in favour of V4L2
Streaming/Transcoding:
optimize and extend DLNA support
fixes for DLNA PlayTo and DLNA folders
fixes for DLNA seeking
extraction of attached fonts for subtitle transcoding/burn-in
small fixes to SyncPlay
add transcoding information to playback data
fix opus sampling rates on transcode
properly stream m3u over HTTP
add keyframe extraction for better seeking (WARNING: this is a really long running task)
overhaul streaming logic to only transcode incompatible streams
various fmp4 fixes
NFO:
add parsing of additional ids
proper importing of watched state
proper parsing of ratings
proper handling of thumb tags
add support for fanart tag
proper casting of NFO ids to internal ids
Scanner/metadata providers:
add ID parsing from folder names
extend ID parsing from filenames
refactor extras parsing (way faster)
refactor and harden parsing of plain folders (all movies in one folder)
refactor and extend external subtitle and external audio parsing (now supports containers too)
properly handle unprobed strm playback with external streams
add support for TMDB absolute and TV order
properly pass language to TMDB search queries
fetch TMDB parental rating for tvshows
enable fetching additional series states from TMDb
properly detect DolbyVision
enhance detection and handling of DVD/BD folders/ISOs
episode parser improvements
add ability to disable adult content in TMDb
add ability to configure image scale in TMDb
update artist split whitelist
make tag import and maxCastMembers configurable for TMDb
improve metadata merging
add ability to fetch logos with TMDb
add option to configure season name importing for TMDb
Technical:
upgrade to latest .NET 6 (fixes some of the quirks with network storage)
bump all dependencies
upgrade analyzers and properly handle warnings
proper generation and publishing of OpenAPI spec
add and extend tests for various subsystems
upgrade Docker images to Debian 11 Bullseye
include latest Intel Compute Runtime in Docker images
add health check to Docker images
remove unused docker volume for /media from Docker images
make flushing to disk async if possible
Web has been moved completely to NPM (instead of Yarn), and several pages have been ported to React. Further many dozens of improvements and fixes have been made.
switch to NPM
update all dependencies
introduce ReactJS and migrate some pages
redesign of mobile item detail views
SyncPlay improvements
user settings for custom CSS
fixes for TV layouts
book player improvements and new Continue Reading section
change SyncPlay icon
add support for custom links in sidebar (config file only)
add support for new QuickConnect
update settings to reflect server changes
properly name generated bundles for cache-invalidation on update
implement markdown for plugin changelog rendering
add hardware transcoding info to playback data
enable buffering in the web player
switch volume slider to exponential instead of linear scaling
remove tag filter limit
fixes for theme songs and videos
unify duration display
add item count to playlists
expand metadata editor
various fixes for webOS
fix and extend multiselect
save playback speed between media
introduce WebWorker for blurhash decoding
update translations
add apple device icon to activity log
save pdf “playback” on page finish
stack toasts
add paging to list view
display series level extras on series page
extend LiveTV pages
extend mediainfo dialogue
escape most HTML
add rewatching to next up
allow markdown in login disclaimer
fix theme colors
tackle accessibility issues
fix album track sorting if audio files have SortName tags
add track sorting for videos
Our custom FFMpeg has been upgraded to version 5, along with numerous HWA enhancements and improvements.
update to FFmpeg 5.0.x
rename Debuntu package to jellyfin-ffmpeg5 for backwards compatibility
update existing patches
add patches for CUDA and Intel Quick Sync tone-mapping improvements
add patches for AMD Vulkan-based HWA and tone-mapping
add patches for CUDA & OpenCL tone-mapping support for Dolby Vision profiles 5 and 8
self-build and include latest Intel media-driver, required libraries and vainfo
migrate CI to Github Actions
add build script for win64
add required libs for QSV on 12th gen Intel hardware
add chromaprint
remove deprecated distros, add newly released distros
add patch to support long path names on Windows
All plugins have been updated for Jellyfin 10.8.0, as well as numerous day to day enhancements.
A point-form list of (some of) the changes compiled by the team is:
migrate CI to templated Github Action workflows
fix trakt.tv plugin to actually be useable
Thanks to the many dozens of generous volunteers over at our Weblate (https://translate.jellyfin.org), thousands of new translations are available in Jellyfin 10.8.0 for over 3 dozen languages.
Happy watching!
