by Joshua Boniface
Our GPG key for signing our Debian and Ubuntu repositories (https://repo.jellyfin.org/debian and https://repo.jellyfin.org/ubuntu) is set to expire next month.
Unfortunately this was an oversight when we first set up this repo, and we never provided any convenient way to update this. As a remedy, we’ve removed the expiry on the key and put a new version on the repo. This brings us into line with numerous other 3rd-party Debian repositories, such as the Microsoft .NET and Docker repositories which also use an expiry-less key, and should avoid any such issues again, barring a need to rotate it. This does however require manually refreshing the key on your system.
Doing this is as easy as re-running the command from the install docs; it will overwrite the old key with the new one:
wget -O- https://repo.jellyfin.org/jellyfin_team.gpg.key | sudo apt-key add -
You can verify this worked by checking the apt-key output like so; this is a good practice anyways to verify that the key has not been altered, as its signatures and fingerprint should all match:
$ apt-key list | grep -C2 jellyfin  # Notice the expires: field
Warning: apt-key output should not be parsed (stdout is not a terminal)
pub   rsa3072 2018-12-16 [SC] [expires: 2020-12-15]
      4918 AABC 486C A052 358D  778D 4902 3CD0 1DE2 1A7B
uid           [ unknown] Jellyfin Team <team@jellyfin.org>
sub   rsa3072 2018-12-16 [E] [expires: 2020-12-15]
$ wget -O- https://repo.jellyfin.org/jellyfin_team.gpg.key | sudo apt-key add -
$ apt-key list | grep -C2 jellyfin  # Notice the expires: is now gone
If you find this didn’t work, try removing the key first with this command, then re-add it again:
sudo apt-key remove 1DE21A7B
We’ve also published the key to the Ubuntu keyserver as a backup, just in case, or if you prefer this method. Our docs will retain the direct-file method however. You can use this command to obtain the key directly from the Ubuntu keyserver:
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv 1DE21A7B
Please ensure you refresh the key before December 15th, or you will find that apt update no longer works!
GitHub Issue for reference: https://github.com/jellyfin/jellyfin/issues/4528
Reddit thread for reference: https://www.reddit.com/r/jellyfin/comments/jz6u9o/debian_ubuntu_repo_users_our_key_is_expiring/
Thanks, Joshua
